Re: Problem with Orb raw two stage switch
Looking at mine, there is a pin that protrudes through a hole in the negative ring on the contact board. This pin goes to a resistor to provide the low mode. If this pin does not stick out far enough it wont contact the body before the negative ring, so you would lose your low stage. I hope this helps. I have been thinking of putting a FluPIC board in my raw to give more flexibility, has anybody else managed this?
Marc
