Handlobraesing
Banned
- Joined
- Feb 14, 2006
- Messages
- 2,724
I can't believe it, but it happened. Brand new Mag 4D LED loaded with fresh Rayovac D cells. I thought this one was significantly dimmer than my other 4D Mag LED. Well, a little bit later, it became extremely dim, then half of the luxeon die wasn't glowing. I could make it light up by flickering it. Within a minute, entire thing stopped giving off light. Still voltage across LED though.
I've never seen an LED fail until now. I'm not sure if something went wrong w/ the circuit killing the LED or the Luxeon happened to be defective.
The module might not have been able to handle 6.3v OCV (brand new battery) too well or the Luxeon suffered from initial failure.
Luxeon is probably not burned in before leaving factory and in that case, it's not immune from the bathtub curve.
