greenLED said:
Nice job! I am amazed at how much better the XR-E's seem to be compared to the Luxeons.
Could you please post pics of the Cree beam without the diffuser? I'm curious to see the artifacts you are talking about. Any ideas if they're caused by the reflector resizing, poor focus... ?
Not sure if my camera would pick them up very well, especially on my textured walls. There's another reflector thread floating around, the main problem without the diffuser is the same "dark ring" problem around the spot. Other than that, a few artifacts in the spill due to the dome and a tighter, slighly textured, spot is the result. Fairly typical of non-sputtered reflectors other than the dark ring, still perfectly useable but I'm getting pickier about my beams :naughty:. If you want maximal throw you definately don't want the diffuser. I haven't played with placement extensively but good placement should be able to get you pretty close to stock IMS performance. The dark ring is a mystery.
The main reason I went with the diffuser initially with the Luxeon is the ability to use it around people while shining it at them. A diffuser keeps them from looking straight at the die when they are in the spill, it's much more tollerable. A nice beam is a generous side effect of that.
Some things I've noticed about the LEDs. The domes themselves have imperfections so you get artifacts even with an exposed LED (bumps that cause small holes, etc). The die location varries LED by LED, some aren't exactly centered. They aren't much different but I can see it and it probably has some yet to be explained effects.
The stars I received were flow soldered but the negative contacts were not lined up properly and didn't connect, I had to fix that by soldering a glob on the negative contact to connect it to the pad next to the package. An experience that might be frustrating for someone who is not handy with an iron.
