matrixshaman
In my rush to see what the Cree XR-E had I decided to throw it across a well used Surefire CR123 battery directly. Just a touch for a split second to see what she has. Have you ever started a weld with a Mig welder but forgot to pull your helmet down? That's really what this experience reminded me of as I was close in to the LED to touch some fine point V.M leads to the small contacts (which were hooked up to the CR123). I counted on probably an Ohm or two for the leads so no resistor. I'm still seeing SPOTS.... These LED's are truly BRIGHT. So put on your shades or welding goggles before firing one up You just may need it.
