The L2 is a darn nice light, but it will not throw all that far. "Far" being a very relative term. For walking outdoors and illuminating your path and things within 30-40 feet in a mixed-light suburban-type environment, the L2 is just fine on low. Need more light? Just activate HIGH and you have 100 lumens instantly. The beam does not have a central hot-spot, it is all a medium-wide flood. Need to light up most of the side of a suburban house at a distance of less than 80 feet or so? The L2 on 100 lumen HIGH will do just that. Need (or want :naughty
to uniformly light up a 30 foot wide road within 100 feet? The L2 on 100 lumen HIGH will do just that.
Indoors, in typical house/office use, the relatively wide flood beam from the L2 is about perfect. In large spaces or outdoors, the beam is so wide that it gets lost easily.
The physical size and layout and the two stage switch are very nice. The length of the light fits my hands nicely and allows the bezel-end to protrude from a closed fist grip and not have the beam obscured by said hand at all.
Indoors, or relatively close range outdoors, the L2's medium-wide flood is darn nice. The beam characteristic is ALL medium-wide flood, no real central hot-spot.
A P60-type lamp will easily out-throw an L2, just because it is putting a lot of the lumens into a central hot-spot with a quite usable corona/spill as well.
A multi-level LED to throw about like a P60? A U2 would be close, but I think the beam is wider/softer with the U2. A Pelican 3W-HA would be close in hot-spot reach, but that is only one level. A VB-16 with the 4W drive-level would be close, but a little lower overall lumen output.
