ultrafire wf-501b surefire compatable?
DrifT3R
Melbourne, Australia
Hi,
To what extent is this light compatable with Surefire parts. Ie. What will and will not fit? I heard that the lamps are the same.
Vikas Sontakke
Does anybody have this light? If so, can you tell me how do I open it up to access the light engine?
Thanks,
- Vikas
Kraid
Waipio, HI
Hi,
Lamps only. But the Ultrafires have ugly beams.
Thanks,
- Vikas
The head that you can screw off the battery tube should untwist itself in the middle.
Vikas Sontakke
As far as I can I can see, the head is one piece and there is nothing to untwist in the middle.
All I can guess is that the light engine is dropped from the top and then the glass lense is force fitted from top.
- Vikas
mdocod
COLORado spRINGs
the bezel should unscrew, none of the body parts will be interchangable with any other brands, but you should find a relatively standarddized D26 module within, which means it has some room for upgrades, some might fit some might not, kind of a crap shoot with the UF.
Vikas Sontakke
Thank you! The bezel fits so beautifully that I just could not believe it would unscrew. Now that I have opened it, I see that it looks like a standard drop-in modules. I thought these are called P60 compatible but you said this is D26. Do they have same mechanicals?
- Vikas
