Hello all,
I've been lurking on the forums for a few months now...thought I'd finally post.
After reading the many threads on the Tec 40/KPR103/NiMH setup I decided to give it a shot. Well, I'm not having good luck. I believe the problem the length of the NiMHs. They are definitely a bit shorter than alkalines. I'm using Energizer model NH-15, 1700 mah. My questions are:
1)Can any of you recommend a readily available NiMH that might be slightly larger?
2)Is there a way to build up the contact at the bottom of the flashlight body?
3)Could the bulb flange be shimmed away from the bottom of the reflector with a washer of some kind?
Thanks in advance
Thanks in advance
