firestarter4075 said:
hi ive a lumileds 3w luxeon led headlight ive built up for cycling going thru a luxdrive 1000ma buckpack powered by a 9.6v 2500mah battery questions are is this too much of a battery and would i be better with a 4.8v 2500mah battery and what will the expected runtimes be on it with the 9.6v battery will i gain much runtime over using a 4.8v ??? many thanks
The Buckpuck will take care of providing the proper current and voltage to your LED.
1. Let's examine the power draw of your Lux III. Assuming a forward voltage of 3.75v @ 1000mA = 3.75 watts. The forward voltage depends upon the bin of your Lux III. i.e, it could run closer to 4v.
2. You'll be drawing a little more than that from the battery due some inefficiency in the Buckpuck (say 4 watts).
P = IV, I = P/V
For the 9.6v battery: I = 4/9.6 = 0.427 amps, so you'll probably be drawing less than 500mA from your 9.6v battery giving you 5 hours in theory.
Forthe 4.8v battery: I = 4/4.8 = 0.83 amps, giving you nearly 3 hours (in theory). In both cases the light will get dimmer toward the last 25 percent of the time period as the batteries get weaker.
- Hope this helps.
