Hi All,
Time for another Bogus Mod. I've gone as far as I can with the Hotwires by making my Mad Mag Hotwire Hotrod Mod. Here, I give you my Mad Mag Luxeon mod. I could probably take this further with the Cree's at a later date.
Got some LuxI SX0H and reflectors from AW, a Mag3C and some help from my local lathe shop and here's what we got....
The "Little Green Giant"
My custom made heatsink. The bottom has a threaded bit to fit into the Mag head
Testing for fit
And here it is! Body cut down to under 2C size to take 2x18650s.
Breakdown
The heatsink and LuxI's assembled
The bottom battery PCB fitted (used a 0.5 Ohm 2W resistor for DD)
Head assembled
Modified forward clicky tail cap
Another look at the tail cap
The tail cap diassembled
Showing how the switch fits inside the first Ring and the second retaining ring screws in into the tail cap. Used heatshrink on the spring to prevent it shorting against the threaded ring.
The beam shots!!
Left is LGG. Right is SLPP LuxI - for comparision since I guess most people will have a SLPP LuxI
OK, so that wasn't quite fair... how about the Microfire 10W HID? Again LGG on the left, distance to door about 8 inches.
Another one, distance about 2 foot
Ceiling bounce - Microfire 10W HID
Ceiling bounce - LGG
If the Microfire 10W is 450Lumens I guess the "Little Green Giant" is a little less than that - maybe 400Lumens?
In reality the Microfire 10W has an immence throw. The LGG can't really match it but if talk about overall light then it's pretty close to the Microfire.
The LuxIs are are in 2S2P running off the 2xLi-Ion18650s, through a 0.5 Ohm 2W resistor. Current draw is 1.7A. So each Lux is getting about 850mA. Someone please tell me if this is safe or are the Lux's going to fry? After 10 mins running the head is warm, not that hot really, so I guess the heatsink is doing a good job.
So I've done my Hotwire. I've done my Luxeon. Stay tuned for my HID!
Thanks for looking.
Bogus.
Testing for fit
Breakdown
Head assembled
The beam shots!!
Thanks for looking.
Bogus.
