Most RGB laser projectors have the capability to do white light. They have a 3 lasers in them, R, G, and B and when combined they make white. I hear the best ratio of color is 4 parts red at 671nm, 1 part green, 532, and 1 part blue, 488 or 473, there was a small discussion about which is the best blue. Some have said 514 is a better green also, but... :shrug: I also read that ratios are BS, you use what ever "looks" like good white.
Lasers used in projectors are oneof two types, or can be modulated in two ways, ttl (no idea what it stands for) and analogue. TTL uses a +/-5volt signal to turn the laser on or off. Analogue... I think used +/-5 volts to turn the laser's power up and down gradually. A 100mW laser could go from 10mW, 15, 20, 30, 50, 75, 100... A ttl projector can do "7" laser colors, R, G, B, additive colrs, and Yellow, Cyan, Magenta, subtractive colors, and White, all colors. An analoge projector can use varying degrees of all 6 additive and subtractive colors to sumulate any color, up to 16 or so million. :candle: And white...
