wquiles
On another Cree-related phost, somebody mentioned that the deep reflector in the Dorcy 3D 1W LED light could be a good potential reflector for the the new Cree becuase the Cree seems to benefit from them.
I just got 3 XR-E LED's (mounted on stars), so I will try to try it soon, but I wanted to share how really deep these reflectors really are!!!
For my own McG45 custom light I am already using a very deep reflector, the superb 45mm from Don :rock: , as used in the HD45 LED light.
In order to make this reflector work I had to "push" the LED/heatsink deep into the body, as when the head is screwed into the body, part of the reflector is literally inside the main body!
To see how it would work in my current McG45 prototype, I fitted the Dorcy reflector to a standard M*g C head and compared to one of my McG45 heads:
Note that the Dorcy reflector is even deeper than the 45mm reflector:
This is how the McG45 head looks like at optimum focus, from the top and from the side:
and here is how the Dorcy looks like in the same exact body:
These beamshots are still using the McG45's W-bin 5W LED, but should be good enough for now to compare the two reflectors (as always, Canon Rebel XT, kit lens on wide angle, all manual exposure/focus):
Dorcy reflector:
45mm reflector (note the center is wider, as well as having a slightly wider beam and a little bit better transition from center to sidebeam):
And aimed at a different target:
Dorcy reflector:
45mm reflector:
I will "try" to modify another 1C host and modify one of my McG45 custom heatsinks to work with the Cree star so that I can have a comparison on both of these reflectors
Will
Dorcy reflector:
Dorcy reflector:
45mm reflector:
Will
