<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by jmm:
Craig, the ball's in your court. Deep down, you know you really need a DECENT new computer (and we do too). Lonewolf has proposed a solution, but we need your input and blessing to proceed.<HR></BLOCKQUOTE>
Well, let's see if I can post this before the thing goes ****-up again. Took two tries to finish my post in the "Darell's Baby Pictures" thread. Going back will kill the browser, so I'll have to try to do this on memory.
Regarding the Toshiba's video RAM. The OS thinks it has 512K, while the person who knows this machine thinks it has 4 or even 8 megs. Not sure what's going on with that, but I'll trust the previous owner on this one. Windows NT apparently does not "auto detect" new devices installed onto it, so maybe it figured it had a crappy 10" VGA monitor on it and refused to change the screen size or color depth based on what it did not know. :-/
Regardless, the machine would still make a decent server and may have enough space left on its 4GB partition to save important files as backups from the work computer once I re-learn the fine art of connecting multiple PCs via network. The last time I ran such a setup was in the early 1990s when I ran a BBS, and I used Lantastic and lots of coax cable with BNC connectors & terminators. Much of what I learned back then has long since been forgotten, so I'll have to go back to school for that, so to speak.
With regards to using another HD to back up my current work environment, I don't have a HD large enough to store everyhing on, other than the HD I'm using at this very moment. So a total system backup is not possible with my current setup. Several smaller HDs could do it, but I'm not sure how I'd pull that off with the Toshiba, as it is apparently not expandable in that regard. It does not have the space to install a second HD inside; and it uses a custom HD cable with a single connector on the end, not two connectors like most machines have. I had the machine apart the other night, and when you yank the HD, you find a custom switching PSU directly underneath with no room to spare.
Regarding the monitor. The one I'm using is a CTX 1765, which is a not-that-bad 17 incher. It's good up to 1024x768 before text becomes fuzzy and hard to read.
The other monitor is a Viewsonic-7, which has a noticeably larger dot pitch so it's not as good for graphics as the CTX. So the Viewsonic lives on my ProMetric machine. It's good up to 800x600 before text becomes fuzzy and hard to read.
Regarding the OSs. The Toshiba currently has Windows NT on a partition, and according to Artie, there's a 4GB partition free with nothing on it at all that could host another OS or serve as remote storage.
The ProMetric machine runs Windows 98 and DOES NOT CRASH, and I'm not looking to change that in the foreseeable future. If it isn't broken, why fix it?
This machine (the one I'm typing on right now) is the pisser. Every time I install Windows 98 on it, it looks different. And it crashes all the time, usually blowing out the kernal core with Exception 14 after all the open applications have crashed and/or been unloaded. More often than not, it freezes up so I have to punch the reset button and then repair the HDs when it comes up again. This machine hosts all of my web material, HTML and photo editors, and the like.
As for applications I depend on, they would include Gomer (an HTML editor), Photosh+_¢å
