IsaacHayes
Finally got around to putting the SX0H luxeon 1 into the ultrafire. Before the mod it would not light on voltages 1.2v or lower. It would stay lit as the battery went to those voltages, but turning off then on resulted in darkness.
Now it will light on 1.06v recharable alkaline (and imediatly dims down as the cell is dead).
I measured a variety of luxeons hooked up to the circuit and no matter what Vf, the circuit always delivered 250ma to the led's. So I'd say it's safe to declare it 250ma CC flat regulated circuit. I guess the stock clone Vf was high enough that the circuit could not stay in regulation at 1.2v, and refused to fire up.
Now it fires up just fine, and is brighter than my fenix. Also the beam is wider on the ultra fire too with some corona around the hotspot. It's not double bright, but I can tell a difference.
Runtime seems to go on forever using amondotech 2600mah NiMH. I don't want to say yet, but I'm going to guess at least 2 hours flat output. Yes flat, this doesn't dim like my Fenix L1P. Of course that's becuse of the CC circuit.
These lights aren't bad once modded, but you need a premium low Vf luxeon to make the CC circuit worthwhile. Stock, the circuit isn't a good choice.
I may send this off to someone who can graph it. It's suprising me.
