vetkaw63
Everyone is talking about the terrible heatsinking from the stars that the cree's are ariving with. I was wondering if anybody had thought about measuring the thickness of the star, flipping the star over and, plunging to depth with an endmill. This would create a counterbore underneath the emmitter. Then you could turn a heat sink with a small pilot which would fit in the counterbore. Then you could either reflow solder or, use thermal adhesive to bond the emmitter directly to the heatsink. I haven't seen a cree xre yet but, I thought maybe you would not have to use the top pads to solder to. Then you would not have reflector clearance problems. Is this reasonable?
Mike
Mike
