stockae92 said:besides Fenix P1, what else out there has a flat fully regulated discharge curve, 3W, single CR123A, glass lens, compact in size and relatively affordable?
thanks
You can make it act like it has a momentary switch if you turn it so it is just off, then press the head to the side and it usually comes on. You may have to try it a couple of times to get it to work.savumaki said:Now if I could just get a P1 with a momentary on switch all would be well in savumaki land.
Blindasabat said:You can make it act like it has a momentary switch if you turn it so it is just off, then press the head to the side and it usually comes on. You may have to try it a couple of times to get it to work.
Pumaman said:I have had many inexpensive single cell lights. the p1 is unbeatable in price vs size vs brightness.
GrooveRite said:I concur!
What I want to know is when is fenix going to release the Cree XR-E P1 :naughty:
LowTEC said:^^agreed! Cree P1 with clickie and hi/low RCR123A, I probably won't buy anything else after that......maybe... :lolsign:
..... Don't think so ............... measure twice/cut oncecoontai said:Spend a little more and get a wolf-eyes 6 series (sniper) with the led module. Its about the same size.
