mdocod
I've been wanting to do something to my 3D Dorcy 1W for awhile, it has great heat-sinking so I figured it could handle more oomf..
I successfully desoldered the lousy lux it came with, (horrific green tint).. and resoldered in the one that came in my Task-Force 3xAAA 1W(near perfect white, very slight blue).... I also removed the resistor from the path.... but will probably want to put something back in there(maybe)... it's running ~1.2A from 3xNIMH D cells... overdrive crazy... it's now nearly as bright as my LEDBEAMS.... I've heard people say that that luxI emiters are basically the same as luxIII... only difference being that the luxIII has better thermal path...
I think the LuxI should hold up for awhile like this... we'll see...
this is a throw monster now!!
I'm thinking this would be a good host for a U-bin. now just to find one... lol..
[edit in]
I had some free time tonight after work... So I decided to put together some comparison shots...
the first comparison shows a shot of the LEDBEAM and the DORCY as it was stock a few months ago... I couldn't remember the exposure time then.. so I don't have any DIRECT comparisons from the old to the modified DORCY.. but the LEDBEAM acts as a point of reference... the second set contains several exposure settings of the same LEDBEAM compared to the modified DORCY...
As you can see... the tint is a WHOLE lot better, the brightness is not as good as a luxIII driven that hard (the LEDBEAM runs about that same power, 1.2amps not uncommon)... but still a pretty suprising change.
[edit in]
