The_LED_Museum
*Retired*
Ok, looks like the new computer is working well (only two crashes; neither one were fatal to the OS) and I've gotten most of my apps migrated. So now comes the next step: setting up the LAN, and I need some advice on which system would be best to use as a server, and which ones would be best as clients. Initially, I'm planning on connecting three computers. The following is how I typically use these systems:
Computer #1: The new Dell. P4/1.8GHz. Primary usage is for all things Web-related (browzing, writing web pages, etc.), for all graphics work, and for playing music in the background whilst I toil away. This computer is by far the most frequently-used machine; actively used up to 16 hours a day. Runs Win XP.
Computer #2: The Gateway 2000. PII/350MHz. Primary usage is for the ProMetric system. Hardware dongles are in place, eliminating the EPP port. There is also a security device in one of the PCI slots, and a video capture board in another. Little else is done on this machine except an occasional game of Wolfenstein 3-D. Typical usage is approximately 1-2 hours a day. Runs Win 98; may upgrade it to Win 2000 if the ProMetric doesn't object.
Computer #3: The Toshiba. PII/233MHz. Machine is currently unused (until I buy a hub for the monitor to share same with the Gateway), but I'm planning to use it with a spectrometer (connected to EPP port) and a recording DMM (connected to a COM port). I may also use this one to connect to a local, dial-up BBS on occasion (1-2x a week). Runs Win NT.
So the question is, when talking about a LAN hookup, which machine should serve which role? I just received the LAN hub (Thanks Lambda, non-sarcastically of course
) and I think I have enough Cat-5 to get at least the server and one client going right away without having to make a run to Office Depo in the pouring rain for more cable.
Suggestions?
Ideas?
Suggestions?
Ideas?
