tibim
So I just got a new(to me) U2 yesterday and it's having some problems. Output is good and everything 'till I put it in the lowest mode(1) and let it run for a few minutes. Then the light starts to flicker and goes into a SUPER low mode(I'm talking I can look directly into the LED and see the circuit, almost no light output). When it does this turning the power ring has no effect, the light continues to stay in this super low mode. If I turn it off and turn it back on, it will go into mode (1) and then flicker(sometimes back and forth between the high modes) and eventually end up back in the super low mode. If I let it sit for a while it will operate normally, till I run it in low mode for a few minutes and the whole cycle repeats.
The light came with batteries and I dont think they're low yet because I can run it on high mode(6) reliably for minutes(haven't had much time to test) without it going any dimmer.
I'm not sure if the light would start to flicker in any other power modes, but I can reliably make it start to do this in level 1.
Any ideas on what it might be? Tailcap? Something messed up in the head?
