NewBie
*Retired*
Both LEDs will be qualified according to automotive standard AEC-Q101 and easily achieve the brightness level of halogen lamps.
The two models have a high colour temperature of 5600 K that is closer to natural daylight than other headlight sources. In particular this improves visibility at the edges of the illuminated zone because the human eye is better at perceiving objects in day-light white light than in other light colours. The LEDs provide concentrated light from a small surface area and are therefore ideal for use in headlights.
http://www.osram-os.com/download_protected/press/rtf/PR_OSTAR_Headlamp.rtf
Pictures of the module here:
http://www.osram-os.com/download_protected/press/tif/300dpi_PR_electronica_booth_concept.zip
It looks like five dies and
"For a typical forward current of 700 mA the OSTAR Headlamp achieves 250 lm"
So probably we are looking at needing 12 Watts in the OSRAM "super LED headlamp". 250lumens/12 Watts = 20.83 lm/W
I guess, in a car, you can afford the losses, the heat, and heatsinking requirements.
