Bullzeyebill said:
I suggest you do a bounce test off ceiling for each light and record the lightmeter readings. Do this in a relatively small room, say a bathroom at night, or with no windows in daytime...
Ditto that. A bounce test will tell you a lot about the overall output of each light.
Flashlightreviews test of the U2 and L5 shows the L5 has slightly more output, but the U2 has better throw. However that's a sample size of one.
There can be considerable unit-to-unit variation. Doing lux meter bounce tests as described above, my U2 outputs roughly 2x my HDS U60, which are supposedly individually calibrated to 60 lumens. My first U2 wasn't as bright, plus had tail switch problems, so there is variation. You can return it to Surefire for a replacement.
For a given light, there are (at least) two beam widths involved, the spillbeam beam angle and the hotspot beam angle. There is also a division of the light's overall output between spillbeam and hotspot. Some lights put more output in the hotspot and less in the spillbeam, and vice-versa.
Besides the actual output level, the division of output between hotspot and spillbeam, plus the beam angle of each all drive our visual perception of "brightness".
The U2 diverts a lot of output (about 79%) to its spillbeam, which is very bright. However the U2's spillbeam angle is relatively narrow at about 60 degrees. The U2 hotspot beam angle is about average at 8 degrees.
By comparison the HDS U60 diverts about 73% of output to its spillbeam, but has a spillbeam angle of 74 degrees.
The A2 (on incandescent) diverts only about 44% of output to its spillbeam, leaving more for the hotspot. The A2 incan. spillbeam is a broad 100 deg, so it's relatively dim. The U2 spillbeam by comparison is narrower and very bright.
Spillbeam measurements based on a single lux measurement at 1/2 the spillbeam radius, so it's a crude approximation but roughly illustrates the differences.
You tend to get accustomed to a given light's characteristics, then the next light compared may look odd. E.g, My U2 spillbeam angle normally seems fine. However when I use my A2 for a while which has an approx 100 degree spillbeam angle, then switch back to the U2, the U2 spillbeam seem very narrow.
I don't have an L5 to measure the spillbeam angle, but the hotspot beam is likely broader than the U2, based on FLR data. The U2 beam angle may seem narrow by comparison, but in actuality the U2 has a general-purpose hotspot beam width, roughly the same as the HDS U60 at 8 degrees. The U2 spillbeam angle is a little narrow.
The U2 is a great light; I'd suggest returning it to Surefire and asking for a replacement if you're unsatisfied in any way. The variable output has great utility, vs a single-level light that's often too bright and quickly depletes batteries.
If you want a completely different light that gives some of the U2's characteristics in a smaller package, try the A2.
