Should be so easy! But Im having difficulty!
I pop the buttom off and (meticulously) widened the small hole through the plastic...
Problem is.. when I stick my screwdriver in I have to put it at a slight angle to reach the pot. Im not sure if its making contact. Even if it is I'm thinking the tip of my philips is too thin to grip the "crossthreads. I'm not getting any resistance and nothing is turning. I can't see because the shaft is too thick.
Anyway, I tried using an exacto knife and I can actually see myself making contact with one of the little grooves but when I apply force the thing wont budge. I read that someone actually broke there pot off while trying to turn it so I'm very afraid to try too hard. Any suggestions? Anyone else have difficulty turning it?
I just want to try it ever so slightly (I really dont want to effect the overall quality or life of it).
Thanks
Thanks
