Malkoff
Page 1 of 4 1234 LastLast
Results 1 to 30 of 103
Thread: PXR Cree Heatsinks
    Flashaholic* modamag's Avatar
    Aug 2004
    Bay Area, CA
    Default PXR Cree Heatsinks
    One of my longtime dream is to have a light lb/lb (kg/kg) be able to best those of the Incandescent and HID crowd. I have made many attempt at this but failed until now! JimH knows is probably is still laughing.
    The introduction of the Cree 7090 XR-E revitalize this dream. Finally! "WE", the crazy white wall hunters have reclaimed our midsize thrown from the incans and with a chance to best those HIDs in the total lumens output category.
    Without further a due, I introduce to you the PXR series of heatsinks, built on the foundation of the PTS2 series heatsink.
    === Features ===
    1. Available for use with 3 or 4 Cree XR-E emitters
    2. E-can integration. Standardize to 0.800" converter size.
    3. Threaded/Lock into the Mag head
    4. Pin hole for additional screw tap and leverage for installation. Reoriented for ergonomics.
    5. Center 5/16-18 tap for ...
    === Recommended Host / Batteries / Driver / LED combination ===
    Mag2C / 2x18500|2x18650|C-LiIon / Shark|Fatman|MaxFlex / 3|4x Cree XR-E
    Mag3C / 3xC-NiMh / Shark|Fatman|MaxFlex / 3|4 xCree XR-E
    Mag3C / 3xC-LiIon / Shark|Fatman|MaxFlex / 4xCree XR-E
    Mag1D / 4xAA-NiMh / Shark|Fatman|MaxFlex / 3x Cree XR-E
    Mag1D / 4x14500 / nFlex / 3x Cree XR-E
    Mag1D / 3x17670 / Shark|Fatman|MaxFlex / 3|4x Cree XR-E
    Mag2D / 6-8xAA / Shark|Fatman|MaxFlex / 3|4x Cree XR-E
    Mag2D / 2xD-LiIon / Shark|Fatman|MaxFlex / 3|4x Cree XR-E
    Mag2D / 6x17670 (series) / nFlex / 3|4x Cree XR-E
    Mag2D / 6x17670 (ser/par) / Shark|Fatman|MaxFlex / 3|4x Cree XR-E
    Mag2D / 8x14500 (series) / nFlex / 3|4x Cree XR-E
    * Listed in order of performance per size and level of difficulty
    === Recognition ===
    Special thanks McGizmo for the cool/efficient McR-19-XR reflectors.
    I also want to thank CroMagnet for the 2 years of constant nagging to get this done.
    Enjoy everyone!
    Default Re: PXR Cree Heatsinks
    YAY, finally Cree Magsink!
    Price? availability?
    Sep 2002
    A very strange dark place
    Woohoo!
    Wait a minute... are you going to build a 3 XRE heat sink that holds the Stars? If not, I had better change my pre-order for those Q2 stars! Please let me know quickly so I can adjust my order soon. Ack!
    Peak Pacific AAA UP brass (EDC) E01 (keys), Peaks, Arcs, Fenix, Q5 Aspheric HA-III Mag etc.
    VERY nice!
    So how do you make all the solder connections? What reflectors are being offered for the CREE? Any chance of building a sink that supports the star or disc?
    Flashaholic* Sway's Avatar
    Aug 2003
    North Carolina
    Those look wonderful Jonathan, I can't to get one up and running
    Later
    Kelly
    Lucas Jackson, "Here, Captain"
    Maliciously destroying municipal property while under the influence, What was that?
    "Cutting the heads off parking meters, Captain."
    Jan 2005
    Texas, USA, Earth
    Awesome !!!
    Will
    Please no PM/Visitor Msg's. Email for questions/Paypal: wquiles [at] gmail {dot} com
    Flashaholic* jar3ds's Avatar
    Sep 2005
    USA
    oh man... how sweet.... no we don't have to mess with with dist. crappy PCB/stars as far as heat goes!
    and the McR-19XR is much more appealing!
    When are these going to be availble?
    Flashaholic* Anglepoise's Avatar
    Nov 2004
    Pacific Northwest
    Smart move to eliminate the MCPCB.
    Good luck with the build,
    David............................................." Some Homemade Creations"
    *Flashaholic* IsaacHayes's Avatar
    Jan 2003
    Missouri
    Lumbee1: You'll need to isolate the bottom contacts to prevent short. Easiest way to do this is to snip the corners off the led, as that's where the trace is for the bottom of the pad. Then only the top pads will make electrical connection. Use some fine wire (24-30gauge teflon works good) to solder to the top pads, and route the wire as best as possible away from the reflectors. I plan to do this, and then solder the small wires to some larger gauge that will be ran longer down the light to minimize resistance.
    Modamag: Great work!
    1) What is the center tap for? Will you offer a bulb extension so it can screw onto a stock body? That'd be cool except for the resistance of the stock mag bulb holder, but would mean you could just screw on different tri/quad heads on one body!
    2) How much extra length does it add to the mag since they are threaded and that will keep the body from screwing all the way into the head? (I'm used to the PTS ver1 design).
    It looks like the D size could be adjustable for varying reflector heights as an un-planned feature too hehe.
    Mags: 2C: R/O, True Cyan, UV. 3C:Penta-XR-E Q5, Single SSC P4. Nitecore D10, Fenix LOD-CE, ArcAAA
    Sep 2002
    Quote Originally Posted by IsaacHayes
    Isaac,
    Think using 22 guage would work as long as you cut some of the strands off (simulated 24 gauge)? I'll have to check the clearances of the McR19 and IMS 20mm reflectors to check.
    Flashaholic* Kryosphinx's Avatar
    Jun 2004
    NW suburbs, Chicago
    Sweet, just what I was looking for!
    Got busted lights? Send me a PM and depending on the situation, I'll take 'em off your hands. I always like a good modding challenge.
    Thumbs up Re: PXR Cree Heatsinks
    Enough with the teasing!! Where's the sales post? I want some copper.
    Great work moda!
    -DF
    KineticParadox ...a personal web space with my CBA Battery Testing and my LED Bin Coding Charts.
    Not trying to go off topic, but what is MCPCB?
    Jan 2003
    Missouri
    metal core printed circuit board.
    Apr 2006
    New Mexico
    Quote Originally Posted by modamag
    Awesome! This is exactly what I need!
    What are the masses for each in Al and Cu?
    When do they go on sale?
    Sep 2002
    OK, changed my star order to emitters only, bring on the PXR-19-De.
    Flashaholic* Icarus's Avatar
    Nov 2003
    Belgium
    Once again you did a great job Jonathan!
    Nov 2005
    San Antonio, Texas
    Perfect! When, where, how much? PayPal armed waiting to fire!
    Ken
    Jun 2004
    Hannover, Germany
    ... nice !!!
    Now we need just a reflector, that is optimized for the XR-E and has "compatible dimensions" to all the older stuff.
    Or ist there one already? I don´t have a clue about MCR-stuff ...
    Then you can "pimp" your old TriLux-Mag easily to a powerfull Quad-Cree ... should be worth the effort .
    1 sink for 2 different configs, VERY clever !!
    Jun 2001
    Malaysia
    Just what I'm looking for!!!
    So what else besides the driver, the xre and mag body do I need to complete this beast??
    awesome!
    Quote Originally Posted by Kevin Tan
    reflectors..... and a UCL (lens) [optional]
    i'm taking this is designed for the McR-19-XR's?
    Jun 2004
    NW suburbs, Chicago
    Quote Originally Posted by nemul
    Considering that the heatsink is able to screw in and out, I'd say that it is compatible with many types of reflectors/optics.
    Apr 2006
    New Mexico
    Any updates on these?
    Nov 2005
    San Antonio, Texas
    Quote Originally Posted by Sawtooth
    Could be before the end of this year if all goes well for him! I`m keeping my fingers crossed and threw a penny in a wishing well to boot.
    My PayPal armed ready to fire whenever he can make them a reality for us!
    Ken
    Sep 2005
    USA
    Sep 2002
    Any idea when the copper PXR will appear? Copper and Christmas trees go together.
    Flashaholic* Christoph's Avatar
    Aug 2002
    Hagerstown,Md
    I have the cree already this looks great pp at the ready.
    C
    Chris
