JimmyM
For Sale:
MagIRC65
This light is a variation on the Mag*** theme. I'm not really sure what to call it. Mag447? MagIRC? FrankenMag? It's built using AWRs Hotdriver specifically built by AWR for use in the big IRC lights and uses the 65W Osram Halostar IRC bulb. It's built in a 6D Mag body with a 3D extension to hold 15 4Ah 1/2D NiMH cells delivering 18V nominal. The Hotdriver is set to 18.75 volts. With freshly charged cells, it holds 18.75 volts at the bulb (until my probes began to melt). I placed aluminum foil between the insulation and the inner surface of the Mag body to reflect IR back inside the body instead of being absorbed by the aluminum tube. The foil and refractory insulation are absolutely necessary to extend run time. This light is truly impressive in it's size and power.
There are no marks on this light. It is flawless.
Included components:
6D Mag Black
3D extension
2 x Osram Halostar 64447 Bi-pin bulbs
Camless MS reflector
Boro-float lens
AWR Hotdriver, IRC spec
KIU ceramic socket
Ceramic refractory insulation
Stubby tail spring with fix
15 x 1/2D 4000mAh NiMH batteries
PVC charging tube
Not Included:
Charger ($30 additional)
Shipping will be via UPS ground. I have no idea what shipping will cost because of the odd size. After purchase I'll PM the buyer with the actual shipping costs.
The first gets it.
PayPal: [email protected]
