Fallingwater
Some time ago, I bought for the car one of those cheapo chinese flashlights that would give the shivers to any self-respecting flashaholic.
Hey, it was €4.
Two pictures follow of the flashlight in its original state:
Its main problem, aside from looking like being made out of concentrated cheapness, is that it uses three AAAs in one of those triangular holders.
I hate AAAs. They are more expensive than AAs but hold less energy, and all for a size difference that is, to me, negligible.
So I took it apart with the intention of building a 3-AA holder and using rechargeable NiMH cells.
However, in the process of taking it apart, I discovered there doesn't seem to be any kind of resistance whatsoever between the cells and the LEDs.
My question is: can you use rechargeables in this light? I suspect it's using the internal resistance of alkaline cells to avoid its LEDs going into thermal runaway, but if that's the case the much lower resistance of rechargeables could turn all the LEDs into friodes... this means it'd probably go pop even if I used rechargeable AAAs...
I also checked the switch for resistance; it has none, it's a simple interruptable contact.
Hey, it was €4.
