iamerror
I have been interested in building a wall of light that uses many LEDs (either white or red, probably 5mm) that are evenly spaced apart. I want it to be something that can hang on a wall or stand up on its own. I want the LEDs to be either running at their specs, or be underdriven. Probably using a standard outlet plug would be best to supply the power, so I could just plug it in.
The problem is, however, I have no LED modding experience. Can someone point me the in right direction with this? Even things that may seem obvious to you... as I don't have much of an idea on this sort of thing. Thanks.
