TranquillityBase
- Joined
- Jun 12, 2005
- Messages
- 3,741
After viewing David's (CPF Anglepoise) lathe tailstock centering fixture for leds, I've had the thought of that neat fixture, in the back of my mind for quite some time now.
Anyway...The Cree has a perfect, built in centering device. The metal ring that the dome resides in is perfect for chucking in a normal drill chuck (use caution, lightly hand tighten only)
I use the weight of the tailstock to squish out the excess epoxy, just don't lock the tailstock to the bed...
I've had great results with this method, and if you have a batch to run, this makes quick work of the job...and no error...
I did have one XR-E star that I bought, knowing the emitter was off center (this was disclosed at the time of sale) and using this centering method, the fact that the emitter was off center, didn't make a difference. I just went ahead and epoxied it to the heatsink, and when the epoxy was hardened, I rechucked the whole assembly and turned the tiny bit off star overhang, equal with the diameter of the heatsink, emitter was dead centered, the star was off center...but it didn't make any difference.
I have more ideas on this same subject...
TB
TB
