A few Cree mod
download
Sol 3
Thanks for all CPF members made this work.
The Cree, O-Sink, MagLED module, MiniMagLED & beautiful Pewter Mag2C .......
All mod were P4 Cree emitter. Let the pictures talk to you.
1. Cree in MiniMagLED 2AA with stock driver, it is as bright as stock MiniMagLED 3AA!!!
A small piece of 1.5mm copper sheet added between it. Stock reflector cut 0.5mm chamfer.
Not much heat I could feel in the body even run more than 15 mins.
2. Cree on O-Sink, same 1.5mm copper sheet added between it.
3. Modded Cree on O-Sink, same 1.5mm copper sheet added between it.
Did you see how small of the light souce? The hotspot is really tight now. :huh:
But the tint did shift to very green. :sick2:
Cree transplant into MagLED .......
Brightness improve greatly in my eyes. Less heat and stay brighter.
Enjoy your mod.
derfyled
Download,
The minimagled is very interesting. Any idea of the runtime ? I'm curious about 2aa running a P4. Have you just swap the led or have you changed the driver ?
Anyway, very nice work !
:goodjob:
cmacclel
Sweden
Your mods look nice and clean... Good Job. Are these for sale? (Custom B/S/T forum)
Mac
download
Sol 3
Administrator, please move this post to the right place, I just shared this mod.
derfyled, no changed of stock 2AA driver, just swap the led. I did not have runtime yet, I thought it should be same as stock.
Mac, Thanks for reminding.
AlexGT
Houston, Texas
Hi download!
Interesting work! I have a question, are you saying that if you remove the dome and metal ring the CREE led changes tint? What tint did it had before you removed the dome? What tools did you use to remove the dome and ring?
Thanks for sharing
AlexGT
download
Sol 3
AlexGT, I just use the cutting pliers and put a pencil backward to limit its minimum opening to remove it.
Yes, it came from original warm white tint to very very green tint now. :ohgeez:
AlexGT
Houston, Texas
Thats very interesting! does anyone know if the dome is vacum sealed to the ring? Or maybe there is some gas preventing the die to go green? If the led tends to go towards the green when dome is removed, what if we get a cree tint more towards the pink side, do you think it would stabilize in white? I mean like WA or YA tint (Luxeon) or WA or WB (CREE)?
AlexGT
Christexan
Okay, a few days late here but since no one else replied, it's reasonable to assume that in the dome removal process, some of the phosphor material came off with it, shifting the tint. Or the dome itself is impregnated in such a fashion as to shift the color tint, I know both methods have been done with LEDs (Phosphor coatings, tinted dome materials, etc), so it could be a combination of these things.
matrixshaman
Outside the Matrix
I'm just guessing but I'd say the bare coating on the LED may be interacting with the oxygen or air and throws a different tint since the dome appears clear.
download
Sol 3
Inside the dome is covered by highly transparent gel type thing.
I just remove the doom from WC tint, the result is much better now. Very acceptable.
kenster
San Antonio, Texas
You mean the tint didn`t turn super green? WC is like XO I believe. What tint would you compare it to in a Luxeon?
I set the ring and dome back on my Cree but I wiped off all the Gel. It stayed really green so I don`t think the dome itself is changes the tint.
Ken
download
Sol 3
Before modding Cree, WC is really white tint, it is as white as X0 in Luxeon. Because it is brighter, it looks much whiter in the real world.
Once the dome removed, it was point of no return. I thought the gel act some function of it. WC did not affect as much as WH tint that the result is sure.
Domeless WC stay white! :rock:
IsaacHayes
Missouri
Guys, removing the dome (unless on accident) should be avoided. It's bad for the led. You will loose lumens unless the ring comes off too, and the silicone gel will boil away and turn milky white with heat over time. If you want a wider beam angle, wait for the SSC leds.
EngrPaul
PA
Some of my WH crees were very greenish, even with the dome.
