With that amperage, you might be OK, but I think KDOG's setup is direct drive using high quality Surefire components and an unknown LED. I have a light with a 2W 2ohm resistor that burned it's resistor solder off, and in my calculations and testing with 10, 15, and 20 ohm resistors, and RCR2's, I was getting up to 1.2 amps DD, and the resistors needed 1/2 W at 10 ohm, and still over 1/4 W at 20 ohm. At lower ohms, you need a lot more wattage capacity. In my 1.2 amp light test I think I remember needing over 1W for 5 ohm. I'd give more specific info, but I don't have access to my notes right now. Some others have done testing...
I did some searching: Look at post #24 on
this thread. Also post number 22 has good info specific to the P1, but probably close to what you would see in the KDOG mutt. jugeh did some testing that helped me get going in the right direction and that I later duplicated in my testing. His charts are way better tham my data though.
Remember to err on the high side here for safety and reliability sake. To be accurate, you need to measure the amp flow through the resistor and gauge the wattage accordingly. jugeh's graph in post #24 of that thread is only a specific example. Look for some of the on-line resistance calculators, they will calculate the
minimum wattage resistor you need.
LEDcandle said:
I run a TY0K direct drive with a 18650 (in a cheap military anglehead), and it's only pulling 400-450ma from the battery. There might be a fair bit of resistance from the cheap materials used in the light, but it seems pretty safe to me. Your mileage may vary...
