Ganp
Does the standard E2e reflector work OK with a Luxeon Led if the head is machined to fit? I'm sure someone must have tried this mod' and I have an otherwise redundant head.
Any info' or links would be appreciated.
Colin.
EDIT
Well I have done the conversion and here are the results.
I milled off the stub in the back of the head ... flush to the surrounding area. The hole at the back of the reflector was not enlarged at all. Then the thread was extended as far into the head as possible. (Cut in the lathe)
Now it is possible to use a light engine, or with an aluminium spacer, refit the MN03 if desired.
Here is the converted head and the components which worked best ... to date anyway!
These are purely subjective views of the results. Luxeon K2's and 5W I was not impressed with due to doughnut type artefacts. The most usefull beams - to me anyway - were obtained with a Cree XR-E, and a Lux lll. Had the reflector been modded differently other Led's may have fared better.
The Lux lll worked best with an optic just placed into the reflector. The locating stub of the optic was ground off so that it would stay on-axis. This extended the bezel by 2.2 mm and I put an o-ring in the gap to provide a new seal.
E2e with the optic and Lux lll installed.
What really surprised me was the beam from the XR-E ... what I would call 'spotless'. :huh:
Yes, it is relatively dim - and I never thought I would like a beam with ABSOLUTELY NO THROW. But I really like this beam. From 6ft you get an even disc of light (to the eye anyway) of 10ft diameter.
Used indoors the eye does not have to keep adjusting as you look into different parts of the beam, and for searching around in cupboards or computer cases etc, it is really easy to work with. On a one cell body this is now a usefull EDC.
On to the beamshots.
These taken at the same camera settings but exposed to show the spill more effectively.
These 6 metre shots taken at the same settings. (Same as each other, not the same as above).
This shot is underexposed in an attempt to give an impression of how the beam compares to the XR-E - allowing for the eyes adjustment when looking into the hotspot area.
It would be nice if the beam from the Cree were brighter and I'll certainly try some brighter bin XR-E's when they are available. I am pretty happy with the results so far and at last I have learned that throw is not everything. :laughing:
Colin.
EDIT
