I know this topic has been hit a lot over the years that I've been on CPF.
Although, I just came across a nice discussion in the CPF Batteries area:
https://www.candlepowerforums.com/threads/144039
...talking about the high discharge rate of NiMH that is made better now with Sanyo Eneloop batteries. I also (finally) understand why alkalines don't do as well in high drain applications (like digital cameras) due to their high internal resistance. Under heavy load, much of the energy of the alkaline battery is simply dissapated as heat instead of doing useful work. Whereas, in a low drain application (like an Infinity Ultra), they can deliever their power slowly and therefore more completely (with less lost to heat).
I have two really nice LED lights, both use 4 AAs, that I like:
UK 4AA eLed ...about 11 hours runtime, fully regulated
SL ProPoly Lux ...about 5 hours runtime, mostly regulated?
So... which would be better to leave in the glovebox if I'm using alkalines 'cause I don't want NiMHs to be discharged right about the time I need my emergency light? ...I'm thinking the one with the lower current drain (the UK 4AA).
On another aspect... I've read a few times here on CPF that multi-cell flashlights can lead to drained batteries because the batteries interact with one another while they are sitting there. And... that if the batteries are "engaged" as they would be in a regular multi-cell flashlight, that they can interact with the case of the flashlight if it is metal.
So... since I can loosen the light heat on the UK 4AA so that it isn't even in contact with the batteries until I need it, is this also a vote for such a light?
And... does this mean that the ultimate glove box light would be a relatively low drain, single cell, battery-not-in-contact light like the Infinity Ultra?
Just some thoughts on an old topic...
