gdhumphreys
OK, so I really like the Jet I MKII I bought, but I wanted it to be brighter. Seeing that others had used rechargeable Li-Ion 14500s, I decided to give it a try. All I can say is WOW. I haven't measured anything officially, but this light with the 14500 is noticeably brighter. I don't know that I can ever go back to using an AA in this light again.
I did note a couple of things: First, the protected 14500s I got from Lighthound fit into the MKII with absolutely no problems. A few people have mentioned that the 14500 in the MKI was a tight fit--not the case with the MKII. Second, all modes worked fine (normal, low, high, strobe), even with the battery hot off the charger--I was under the impression that batteries right off the charger would direct drive the LED, and the various modes would not work until the battery voltage dropped somewhat.
I used a Pila IBC to charge the batteries, but, as the batteries are new, they may not have reached a full charge. Unfortunately, I did not have any test equipment with me. When I got home from work, I tested the open voltage of the 14500 I was using, and it was around 3.7 volts. If the batteries did not reach a full charge, that may explain why all modes worked with the batteries straight off the charger.
Overall, I am really impressed with how this light performs with the 14500.
