Okay, the Fenix P1D CE sounds great to me. Except for one big thing: toggling from level to level. Do you really have to work your way, 1.5 seconds at a time, through three of four levels to arrive at the level you want? When you initially turn it ON, does it always start at the Primary level? Or can it be turned on directly to Low level, or if a blinding flash is desired, straight to MAX?
Here's how the Fenix store describes the operation of the levels:
"Turn the head of the flashlight clockwise to turn on the flashlight. A counter clockwise turn will then switch it off. To toggle between brightness levels, turn the light on, and then turn it off. Within 1.5 seconds after being turned off, twist the head on again and it will be switched to the next brightness level. Just do the same thing to switch it to the third stage and so forth. Keep the light off for over 1.5 seconds, and the light will turn completely off, and the regulative circuit will be restored."
Sounds unbelievably clumsy to me. Could someone with firsthand knowledge please comment? Or redirect me to another thread if this has already been discussed. Thanks.
