I have av an-vss-1 light I am powering. Can anyone tell me how long it will run? It draws 100 amps at 28 volts. I am going to run it with either 2 12 volt batteries or 4 6 volt. Approx. how long will each run it before becoming 40% discaharged? Yes i know alot of the other obviouse things like I will ned a way to charge,keep up, diff kinds of batts. I am only working on wether it will be worth it to have 4 6's instead of 2 12's. Thanks
like this battery:
Volts 6 Amp-Hour 200
like this battery:
