Wim Hertog
I'm planning to do some experimentation on how plants react on monochromatic light or selected wavelengths. As you probably know, the photosynthesis action spectrum peaks at +/- 450nm and 670 nm. There's also some action around 480 nm from the carotenoids.
My question: does anyone know the pure radiometric efficiency of GaAlAs red LEDs (peak at 660nm)? I know the newer GaAlInP LEDs are way brighter, but I think this is mostly because of the shorter wavelengths (<640nm..brightness is calculated with our own eye response curve in mind )...or do they really put more miliwatts of light?
So should I use GaAlInP LEDs which are brighter but have a less favorable spectrum or should I use the 660nm GaAlAs LEDs?
Thanks!
Thanks!
