yaesumofo
Hi fellow flashlight freaks.
Last night I found myself at a buddies house whose place escapes all ambient light. Perfect for beam shots.
I pulled out my trusty Nikon 99o (the camera used in all of my photos that you see here on cpf.
Here is what I got.
These were all 1 second exposures. I don't think I set the aperture (sorry) and the P1d-ce was on it's primary setting NOT HIGH.
NO they aren't the best but they do give some idea of the relative power of each light in a very dark space.
No they aren't perfect.
But they do get the idea across.
Of the three the A-19 from the shop is putting out the most light overall. It is very bright and the color is good. With the greens of the plant life being really clear.
Next is the P1D-ce being next This is not on high (silly me) Again a bright light but with less overall output than the a-19. Not bad. I was going to give this light to my buddy but he doesn't like the interface. I spoiled him with an ARC years ago. now it seems like only a clicky of some sort will do. Makes for a much more expensive x-mas present.
Last but certainly not least is the Modded McGizmo PD with a Cree emitter
This light produces a wonderful beam.
Personally I can't say that these shots represent the beams well.
I am only posting them because so many people ask.
These are certainly NOT the final word but they do give some idea of what is going on.
One important thing I would like to point out is the fact that when you take the light off of a white wall and into a real environment different things become important. beam width and brightness are amongst.
The rings common to the Cree Emitters. The "issue" simply goes away.
(If you notice the file names you notice they do not correspond to the posted names I am aware of this.) The posted names are the correct names for the images.
I am working up a side by side of 4 Cree based flashlight.
The thing is that as flashlight technology progresses our lights become more and more interesting to play with make and modify.
I am quite sure that one year from now (DECEMBER 2007) we will be in love with some new emitter and or some new light.
To be sure though you can't really see it in these beam shots the McXXX PD (Cree modded) is a wonderful flashlight which may take over a spot in my EDC rotation for the time being.
When I took these lights out at my buddies house it is just SO Dark there that when you turn on a light it really lights up the area.
with the small amount of moisture in the air the beam profile comes to light and the light sabre effect comes into play.
One of these days I will go up there and make a set up for shooting Beam Shots and do a bunch of them.
Anyway sorry about the Flaws but I promise they will be better next time...I hope.
Yaesumofo
Here is what I got.
Yaesumofo
