Angryfox
Page 1 of 2 12 LastLast
Results 1 to 30 of 41
Thread: Surefire e1e with Fenix P1 head (pics)
    Nov 2006
    Germany
    Default Surefire e1e with Fenix P1 head (pics)
    I like the performance of my Fenix P1, nice beam, good regulation, 1,5 h runtime. But i dont like the twist on/twist off.
    Yesterday i received a Fenix P1 - CE, and then i went to my small lathe.
    The P1 head fits perfect in the e1e bezel.
    Sorry for my english...
    Default Re: Surefire e1e with Fenix P1 head (pics)
    Got any beamshots?
    Flashaholic* Penguin's Avatar
    Apr 2003
    Diamond Bar, California
    what a great mod!!! planex, the beamshots should be the same as in a regular P1D-CE since he's utilizing the original reflector.
    -Josh
    Fiat Lux
    Flashaholic* MarNav1's Avatar
    Mar 2006
    Nebraska
    If your interested in doing any more of these mod's give us a price and I'll bet you'll
    have some taker's. I know I would like 1 or 2 done. Pm me if your interested.
    Reality is usually scoffed at and illusion is usually king. But in the battle for survival of western civilization it will be reality and not illusion or delusion that determines what the future will bring.
    Nov 2006
    Germany
    Beam, runtime etc. original Fenix P1.
    Its the same head without any modifications.
    Quote Originally Posted by Energie
    oooooh i was hoping it was a drop in fit ... ahhh well !!! Well done Energie
    Nov 2006
    Germany
    Penquin: Its a P1 head. I think, the P1 - CE head would not fit.
    Manarv1: I am doing this just for fun, infected by CPF.
    Mar 2006
    Nebraska
    So it's just a drop in, no machining needed, is that correct?
    Nov 2006
    Germany
    Manav1: Machining is needed, (e1e bezel, P1 head).
    See pic 1: right: original P1 head, middle: machined P1 head
    would you try the P1-CE head ???
    Flashaholic* KDOG3's Avatar
    Aug 2004
    Sea Isle City, NJ
    I take it you had to "lathe" the reflector out of the E1e head? Wow, you'd make a small fortune doing just that! Imagine the possibilities!
    FAILURE TO PLAN ON YOUR PART DOES NOT CONSTITUTE AN EMERGENCY ON MY PART.
    Nov 2006
    Germany
    Hey hey its Hendo: The rear end of the P1-CE head ist too large in diameter.
    It don´t fit into the e1e body.
    Mar 2006
    Nebraska
    Can we get someone to do the machine work for a reasonable fee if we provide the
    part's? I know I'd be in for a couple and I'm sure there's folk's on Cpf who could do
    the machine work. Maybe Milky Lab's?
    Nov 2006
    Germany
    Marnav1: Milky is the right adress! He has made a M-L1 for me, my favorite flashlight.
    Kdog3: I am thinking of the possibilities too...
    Aug 2004
    Sea Isle City, NJ
    Man we need someone to come up with a light engine assembly to go in there! I would want a stippled reflector in mine however. Alright gentlemen, lets' get our thinking caps on! Well, you guys should, I'm too dumb for this kinda thing! I have a black HA E1e body with a matching bezel coming on a black HAIII E2e (which I will be putting on the E1e body). I would *LOVE* to find a decent LED solution for it.
    I'm going to have to give that a try!
    Las Vegas, NV
    Your a God!!!
    Excellent Idea!
    Cheers
    Nov 2006
    Germany
    Thanks 700club.
    But I think, if 4sevens give it a try, it´s showtime!
    Flashaholic* 65535's Avatar
    Dec 2006
    *Out There* (Irvine, CA)
    A handdrill or preferably a drill press jsut put it in and use strips of sandpaper up to like 800 grit for good effect.
    Flashaholic* Long John's Avatar
    Mar 2006
    Spain, near Cadiz
    Hello Energie and welcome to CPF
    Great work you've done
    Do you think it's possible: Unsrew the LE of the P1 D-CE and epoxying into the E1e head, if the OD at the threads of the LE is too wide, sanding down the LE a bit?
    Best regards
    ____
    Tom
    It's cheaper to get a high quality light than spending money for many cheap lights.
    Nov 2006
    Germany
    Thanks Long John.
    I have not opened the P1-CE head, but the reflector is 0,180 inch longer than the reflector of the P1 head. You have to cut down the reflector of the P1-CE.
    The rear end of the P1-CE head (diameter 0,737 inch, electronic only, without bezel) has to fit in the e1e body (diameter inside 0,680 inch).
    I don´t know, how much space the electronic inside the P1-CE head needs.
    Maybe it´s possible to reduce the rear end in diameter.
    BTW, I like the simple P1 mode (on/off), no five stages (P1-CE).
    The P1-CE ist brighter than the P1, but the difference in practice ist not
    so noticable. The P1 head in a e1e is a very good compromise.
    And the beam is nice, flood and throw.
    Mar 2006
    Spain, near Cadiz
    Thank you very much Energie for the reply
    My thought was, using the advantage of the clickie (toogling through the modes) and I really like the form factor of the E1e. So therefore it should be possible, carefully by hand (shure it takes a while).
    Best regards
    ____
    Tom
    Nov 2006
    Germany
    Long John: I like the form factor of the e1e too.
    And I am the opinion, that a (mod) Surefire has to work like a Surefire: solid, safe and with a good performance. Therefore I left the rest of the P1 bezel around the electronic/reflector of the P1 head.
    By using the P1-CE head you have to remove the whole metal around the electronic/reflector . And you have to cut down the reflector, because of the needed space.
    You will get an unprotected P1 - CE head with a suboptimal reflector in the e1e head.
    Maybe it works, but the disadvantages...
    Las Vegas, NV
    I wonder if the Luxogen LR5 or LR12 ineards would work in the E1E without modification? Anyone willing to try...
    Nov 2006
    Germany
    Some pics added: "how to make it"
    http://www.candlepowerforums.com/vb/...d.php?t=145160
    Mar 2006
    Spain, near Cadiz
    Hmmm, thanks for the informations. Perhaps there exists another E-series head which is a little larger (length and wide)?
    Best regards
    ____
    Tom
    Las Vegas, NV
    Thanks for the update. I am looking forward to trying this.
    Would it be possible to use the reflector and emitter minus the P1 head?
    Nov 2006
    Germany
    Long John: You´r right.
    My e1e bezel: diameter 25,33 mm, length 27,19 mm
    My e2e bezel: diameter 25,32 mm, length 28,79 mm
    Different, but not enough.
    Nov 2006
    Germany
    700club: minus: metal body
    plus: center pin
    Mar 2006
    Spain, near Cadiz
    A KL4 head could be the way to go
    Best regards
    ____
    Tom
