flashlightpoor
- Joined
- Dec 19, 2006
- Messages
- 70
I have a surefire M3, A2, and U2. My M3 produces less light with the MN11 lamp than the U2. The M3 should produce 225 lumens to the U2s 100. Can bulbs deteriorate but not burnout? Also the M3 last 13 minutes (20 is claimed) with the MN11 lamp and gets so hot it is impossible to hold (measured 144 degrees F. I know these lights will get hot, but this seems excessive. Similarly, the A2 gets so hot I was using it once to change a tire, had it perched on the sidewalk to illuminate the wheel, and after about 15 minutes I went to pick it up and was surprised by the heat, I dropped it down a sewer drain. If it wasn't for the lanyard I would have lost it. The U2 seems to be the best SF light I have seen. It is not only bright but has a very uniform, circular,white beam. The M3 has a egg shaped yellowish beam. Is there something wrong with my lights or does every one use oven mitts when handling SF lights?
