LA OZ
I just don't understand why reverse clicky is standard when the opposite is more functional and intuitive. So what is the benefit of reverse clicky?
That's why you lock the switch out by unscrewing the tail cap a bit. Takes 2 seconds to do and can save both your battery and in the case of high power lights, your bag as well.Turbo DV8 said:I love being able to momentarily flash a light without clicking it on. In fact, many times that is all I need to do, so I also feel reverse clickies are counter-intuitive. However, a reverse clickie will seldom, if ever, activate itself when smushed around in a fanny pack or such. A sensitive non-reverse clicky can and will, draining your batteries.
Maybe it has something to do with being on the other side of the equator, like how toilets flush in the opposite direction.LA OZ said:Hmm, it was my assumption that it is because almost all of the Chinese lights I encountered have reverse clicky. Perhaps it is cheap and easier to made.
LowBat said:Maybe it has something to do with being on the other side of the equator, like how toilets flush in the opposite direction.
Robban said:That's why you lock the switch out by unscrewing the tail cap a bit. Takes 2 seconds to do and can save both your battery and in the case of high power lights, your bag as well.
