128 LED Chinese.
slurp812
Northwest Ohio, USA
I am a n00b here, but a flashlight/lightbulb freak for years. Just picked up a Chinese 128 led flashlight. The aluminum case seems of really good quality. I havent dropped it yet tho! It is VERY bright for an LED flashlight, but its got 128! It was ~$24 USD total from ebay. I took some things apart, and did some measurements, calculations, ETC. With a freash set of 4 AA batteries , LED's were dropping 3.08 volts, and ~3.6 across the single 5.0 1% resistor. wich figgured to be about 5ma per LED. What you think of these cheapo Chinese flashlights?
iced_theater
Green River, Wyoming
Very bright for the money. I have a 118 led version, I took out the resistor and run it direct drive. Overall output it's brighter than all of my other lights. I sometimes think about putting in high output Nichia led's in place and have a 500 plus lumen light.
slurp812
Northwest Ohio, USA
Any idea on how much current is being drawn from the bettery without a resistor? How long batteries last? I was thinking about putting a 2 ohm in place of the 5 thats in mine. Oh is yours a 4 aa, or a 3 d version?
EngrPaul
PA
It would be interesting if you get better performance with NiMH (less internal battery resistance) and e^2 lithium (more voltage and less resistance).
slurp812
Northwest Ohio, USA
Of course, espicialy with no resistor, but batteries wouldnt last long. My first set of alkalines are down to 1.3 volts apice , and I just put them in two days ago. I added ~2.3 ohms to the 5 thats in there, so its about 7.3 ohms now. Shows no noticable difference in brighness, but will gave me a bit more run time...
iced_theater
I have no idea, if I knew how to use an ohm meter correctly I'd do it and let you know. I have the 4aa version, I'm sure the batteries don't last very long at all though.
slurp812
Northwest Ohio, USA
:lolsign:
OKl thanks. I want a bit more run time, its plenty bright enough...
