Phaserburn said:
Where is a good place to get the KPR139? Is it really that much better than a 4 cell Mag bulb?
You can find them at topbulb.com. I have found them to be much more durable than the Mag bulb option. Keep in mind, getting real brightness from a 4AA light using NiMH batteries means not using a 4-cell Mag bulb, but a
3-cell Mag bulb. Overdriven at that level, they don't last too long. The Xenon versions in particular, but even the Kryptons are at the ragged edge in this setup and can blow if used with freshly-charged cells. Even if you're careful you may not get more than a few hours of bulb life.
I have run kpr139s for many hours and frequently with cells straight off the charger, with no insta-flashes. It is well-suited to this application. It results in about a 7 watt light, which is probably at the limit of what this light will take for runs of long duration.
