hi,
here are some more thoughts on opening the Fenix L0x-heads.
a while ago I tried to open the head of my L0-Ti, but I gave up on it because it didn't move at all and I was too afraid to mess up the finish with more powerful tools. today I read in another thread that EngrPaul has modded a L0-Ti with a SSC P4-LED, so I felt challenged to try again.
here's what I came up with to apply the necessary force and at the same preserve the beautiful finish.
first I cut two pieces from a roadbike inner tube, each of a length to fit on one of the two parts of the head and slipped them on the two sections of the head. then I wrapped the two pieces with seperate strips of duct tape until I reached a thickness of about 20mm. I wrapped as tightly as possible to prevent slippage between the rubber and the head. then I just used two vise grips to grasp the two wrapped sections and unscrew the head. to me it seems almost impossible to mess up the finsh this way, due to the thick layers of duct tape. still you can apply a lot of torque and break the loctite/epoxy this way.
this may work on other lights in a similar fashion, just wanted to share.
edit: when I come to think about it, this may work just as well without the rubber tube, duct tape only.
regards,
david
