I am fortunate enough to get my hand on this wonderful Mac mod. I'd like to thank Mac here for giving me a first chance to proudly own it. Below are Mac's own words, enjoy:
This light operates from 6 Li-ion 17500 cells using a resistored 2 stage tail switch which is On1-Off-On2-Off.
It's running 7x P3 Cree-XR-E's with MCR17XR reflectors. It is WITHOUT DOUBT the brightest mag multi LED light ever created
Light draws 180ma on low and measures 5600 Lux at 1 meter. Estimated Lumens would be around 200.
Light draws 780mah on high and measures over 20,000 lux at 1 meter. My meter maxes out at 20,000 lux and the meter was still rising when it maxed out. Estimated lux would be around 22,000 lux. Estimated Lumens on high would be around 800+ lumens.
As for runtime. The 17500 cells are 1100mah capacity cells
Low runtime approx 6 hours
High runtime approx 1.25 hours
When using this light in High mode it should not be used continuously. I have run it for 5 minutes at a time and the head just gets warm which is fine. But you should never let the head get hot. Low mode and be run indefinitely.
Beam shot compared to Wiseled Tactical (Mac's is on the right, of course
Now with Kiu steel bezel add on:
