LA OZ said:
I believe I have too much an expectation for Cree as my recent experiences with the P1D CE and XR19C have told me. The expected lumen gain was not that useful for me. I need alot more lumen gain to really appreciate it. This scienario is similar to digital camera pixel gain. You need more than double to really makes a difference....
Your experience is consistent with how the human eye works. We don't perceive brightness in a linear fashion, but rather logarithmically. This is more similar to how we perceive sound. That's why sound meters typically display in db, not a linear scale.
The confusion comes from lux meters often having a linear scale. Double the brightness, and the meter reads twice as high. Likewise flashlight reviews post lux and lumen numbers (or similar).
You often hear statements like: "light A is 30% brighter than light B", etc. That only means a 30% MEASURED difference, not a 30% VISUAL difference. Yet it can imply a significant visual difference should be apparent, but it's not.
Lumen increases are not like horsepower increases in a car, where a 20% difference is perceptible in a major way. Lumen variations of +/- 20% or 30% are barely visually significant.
The XR-E's 2x gain in MEASURED brightness at the same power level is a tremendous advance. You can use that to achieve either 2x the MEASURED (not VISUAL) brightness, or 2x the run time, or a combination. But 2x the MEASURED brightness won't appear VISUALLY 2x as bright.
The apparent VISUAL brightness difference is roughly approximated by Stevens' Power Law, the quotient of the cube roots of the two levels:
http://en.wikipedia.org/wiki/Stevens'_Power_Law
Assuming two identical beam patterns, the apparent visual brightness difference between a 100 lumen light and a 200 lumen light is:
100^.33 / 200^.33 =
4.64 / 5.85 =
0.79, or
the 100 lumen light would visually appear 79% as bright as the 200 lumen light, assuming identical beam patterns and tint.
The huge advantage of the XR-E is more easily seen when expressed as run time. Unlike brightness, we perceive time linearly.
E.g, compare the Fenix P1D CE to the HDS U60XR. The P1D CE "primary" output is about equal to the HDS U60XR in "maximum". Yet the P1D run time at that level is an incredible 2 hr 42 min, compared to the U60XR 37 min, both using the same battery type. Considering the U60XR is the extended runtime version using a hand-picked emitter, the P1D CE constitutes a tremendous advance.
P1D CE review:
http://www.flashlightreviews.com/reviews/fenix_p1d.htm
HDS U60XR review:
http://www.flashlightreviews.com/reviews/hds_edcu60xr.htm
