webley445
My 1st mod ! (don\'t laugh)
Been staring at this hunk a plastic for months thinking what I could do. It used to be a handheld "electric" fan. Gutted it and a cheapo keychain LED that I had. The LED used a resistor so I figured I couldn't go wrong, soldered it up, it worked!
Stuck the LED thru the hole that the shaft for the fan motor stuck thru. Have no idea whatsoever of ohms or volts or anything this thing is running, don't think it really matters
. It works and so I am amazed. I have created light! I am master of my world....oh, lost the screw that holds the "housing" together, so improvised with the "temporary containment device" [scotch tape]
. Previous switch was integral with the motor for the fan so have to remove the AA's to turn off and on. Shaft's hole just big enough for LED to fit thru so you have the option of exposed or protected by simply applying slight pressure on the LED (push it inside
) Well, its the first one, waddya expect!
