nanotech17
Anybody have any idea how to mod this torch with Cree LED?
http://profile.imageshack.us/user/nanotech/
arty said:Is there an easy way to get to the switch without taking the head apart?
The switch is very easy to turn on. But, I can't see how you could turn it on in the case, if you inserted it properly.
nanotech17 said:i try to unscrew the silver ring on top of the star but still failed.
it was so tight that i had to wrap my hand with the cloth but that ring is so tight .:scowl:
arty said:This light has a hair trigger - it is lighter than a tuned Colt 45...
I turned it on when I picked it up!
big beam said:Hi NT17
that looks like a nuwai 352
I have one and if you want to bring it to life try 2 rechargable 123's
1.24 ma H
.68 ma M
.37 ma L
The driver seems very robust but I only use high as a burst mode.
BTW mine has an X bin
DON
Long John said:I forgot to mention. In addition to your Lux-measurement, the regulation seems to be a step up converter with a very flat line. Specially with one RCR-cell. I measured at the Led with 2xprimarys 6,53Volts on high. With 1xRCR LiIon 6,3 Volts.
Runtimetest: about 1 hour 45 minutes on high
3 hours 30 minutes on mid and 7 hours on low with one 18650 cell.:rock:The brightness looks the same like 2x primarys.
Best regards
_____
Tom
nanotech17 said:Tom,
Where did you purchased the WX0S?
How much is it?
