there's been many surefire M6 solutions, but all have got shelved due to promotion of HDM6 project.
super lucky to have two M6R packs. runs much cooler than original pack. allows continuous 25 minutes runs with #41 pack, 20 minutes runs w/ #007 pack.
performance with M6R gives soft starts and white beam for entire run. lumens goes up to 600+ lumens with NM21 hola. bulb costs is not an issue, due to extended bulb life w/soft start.
best of all, M6R retains original form factor with no mods. original pack drops right in for instant backup. so use M6/M6R like a regular light, the have a fresh M6 battery pack loaded on standby.
no question li-ion packs more energy. IMHO high drain MNH packs would more likely make into production due to reduced liabilities VS running high drain li-ion pack in series. internal protection or not...
FYI, as most knows... JS is not making any more M6R packs and HDM6 is questionable at best and requires internal changes.
those who's been working on M6 rechargeable solutions should plow forward....
