parnass said:I don't own an XO3, but I measured the current consumption of a couple of XO2s at 350 - 360 milliamps, using the included CR123A batteries.
It would be instructive if someone could measure the current consumption of an XO3 so we could compare it to the XO2.
xm_8 said:Inova XO2 vs. XO3. How much more throw do you get with the XO3? How do their runtimes compare? Which rechargeables will work for both?
OLD_BJC said:I just read the current draw from the batteries on my XO3 and it is 525 milliamps. This is on my 3.8W XO3 (2006 version).
Illum_the_nation said:XO2
throw: 884 lux
output: 2000
runtime: 4 hours to 50%
actual testing: mine lasted about 4 hours and 15 minutes before taking the plunge, testing from my radioshack stopwatch and fresh surefire batteries.
regulation: full
XO3
throw: 1960 lux
output: 2850
runtime: 2h30min to 50%
actual testing: mine lasted about the same before significant dimming became an issue....
regulation: full
sources: www.flashlightreviews.com
current draw measured from the TC? that would give you the amp draw to the converter board.... .525 x 6V = 3.15 watts:huh2:
and btw....inovas dont rust...but there is an inova clone made in china that does.
OLD_BJC said:Why didn't you read the secret message?
lightinsky said:...My XO3 is white tinted but while I was at Target I checked the XO 4.8 Watt and it had a blueish tint to the beam when comparing it to my XO3 and the others they had.
