Gryloc
First off, I want to say that nothing good ever happened to me while working on my LED projects after 2:00 am! I was testing the output of my new Cree XR-E that I got from Cutter Electronics and using different optics when the thing just stopped working. Doh! I just want some help to me point out what I exactly did wrong.
I was using a spare Fatman boost circuit that I made into a special enclosure for testing all of my new LEDs to find the Vf of the LED at specified current levels. I would have this hooked up to my meter and using a strategically placed switch, I can measure either the V out (for the Vf of the LED), or the voltage across the 0.1 (or 1?) Ohm resistor on the board for a nice current measurement. I have two lead wires that I would solder to the contacts of the LED (must be soldered because I can fry the Fatman if it is on and the output is open).
I have tested over 45 LEDs successfully (for my LED headlight project) with this setup with no problems of any sort so far. I was doing something differently this time though. I had a simple toggle switch set up so I can switch the negative wire out of the circuit either to the negative wire of the Cree XR-E or the negative wire of a spare u-binned Luxeon K2. The positive wires of both LEDs were soldered to the positive wire of the circuit. I know the Fatman is pretty durable because I know of several times that I had a poor connection and I have turned on the Fatman with no load for fractions of seconds before (I have a momentary switch hooked up between the battery and the circuit by the way). The voltage on the meter will read like 15V for that very brief instance. No problem...
After I finished soldering all of this up, I lit up the K2, then then I tried the Cree to compare, but nothing happened. I switched back and the K2 lit up fine, but I switched to the Cree and nothing. My meter would read the odd 10-15V when I would do this, like there is an open circuit. What the heck? I tried reapplying power briefly to the Cree while wiggling the wires and nothing. I disconnected the Cree and tried three alkaline batteries together (only 4.5V -which I had used with success before), and nothing. I thought the wires were broken so I tried connecting power directly to the contacts and nothing is happening. I was confused and frustated by this point.
I thought maybe the Cree was hooked backwards, but I think I remembered that the positive wire was always soldered to the positive wire coming out of the circuit. I am sure that it was hooked up right, but I am just making this error a possible option. I know that boost circuits can create a too high of a voltage when left open, so I do not know if I applied power to the circuit then to the LED by accident, giving it a short pulse of ~10V or not. That error is another option.
So you know, I had this Fatman hooked up to the Cree by itself without the stupid switch and it was fine. I was testing the Cree out at different current levels and it was spectacular! I tried different optics and stuff without problems, then I wanted to test overall brightness and compare with the K2 and everything went downhill.
Do Cree's have the same two zener protection diodes the the Luxeons have (that I am familiar and used to accidentally messing up)? If so, How would they even be used if the middle heat pad is electrically isolated (unlike the Luxeons)? The bond wires couldn't have been fried. They aren't discolored from heat, but I can hook up my meter to the bare XR-E and have it to the diode testing setting and it tells me it is an open circuit. Is the die itself totally destroyed? I have a LED that looks completely fine but is completely unusable... aye carumba!
See what I mean by a noob like situation and a noob like question? I am just totally confused and frustrated on what I did that destroyed my new and expensive LED (which I ended up paying in Australian bucks because they didn't convert it to USD -a near $10 difference). What should I do? Should I give up on the thing and maybe try getting another, or can I hook it up differently and get it to still work, even without the ESD protection (if it has it)? I have many questions and I understand if many of you don't want to reply because of that. Thanks all for your help. I know that the CPF is awesome.
-Tony
-Tony
