Valpo Hawkeye said:
In the ML-1 info therad he says you can but the diameter of the cell is an issue. Now if only mine would arrive I could verify. *patiently waiting*
Well, uh... Valpo's right!
Electrically, there seems to be no problem running an RCR123 in the Milky L1... in fact, Phaserburn uses RCR123 exclusively in his, and has done so for quite some time now with no problem at all.
The L1 body in STOCK form (which is how it arrives in a typical Milky L1) has a battery tube that's very tight... normal 123 cells fit fine but protected RCR123 doesn't. There is one brand of UNPROTECTED RCR123 that fits well... the MP brand. See the
Milky L1 Info Thread for more info and photos of that cell.
The battery tube can also be widened a bit if you have appropriate tools... doesn't take much, and the result allows you to fit any RCR123 without problems. Just be careful not to bore so deeply as to damage the electronics! They sit in the top half of the body.
oo:
