Colorado Fatboy
- Joined
- Oct 8, 2006
- Messages
- 85
So I'm out with my dogs late last night with my M*g85 in hand. All of the sudden I hear a small pop then it went dark.
Yep, the bulb literally exploded! I took it apart and dumped the glass fragments into the trash can. There was a white/gray residue all over the reflector and lens. Cleaned them with alcohol and microfiber cloth.
Put in a brand new bulb and if fired right up. I left some small scratches on the reflector and lens but it doesn't effect the beam any.
So what could have caused this? I've only had the light for a short time so I don't know the age of the bulb. Also the temperature was about 14 degrees F. Could the cold/heat generated by the bulb cause this? It was only on for 5 miutes or less. Also it was near the end of the batery pack charge.
Or is it just the nature of pushing things to the limit?
Here is what is left:
